Activity Forums DVD Authoring DVDSP 4 and DVD Player compatibalty problems.. Help!
  • DVDSP 4 and DVD Player compatibalty problems.. Help!
    Posted by Bryant Gover on September 16, 2008 at 1:36 pm
    SO I have a project I shot on two Sony HVR-A1’s in HDV. I captured using one of these cameras to my Powerbook G4 laptop. Didi all editing in FCP 6.0.4 then I exported using Compressor 3.0.3
    Video Encoder
    Format: M2V
    Width: 720
    Height: 576
    Pixel aspect ratio: PAL CCIR 601 (16:9)
    Crop: None
    Padding: None
    Frame rate: 25
    Frame Controls: Automatically selected: Off
    Start timecode from source
    Aspect ratio: 16:9
    Field dominance: Automatic
    Average data rate: 5.8 (Mbps)
    2 Pass VBR enabled
    Maximum data rate: 7.8 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 12, Structure: IBBP
    I then Imported all assets into DVDSP 4.2.1 and did the menus in Photoshop CS3
    I’m choosing all regions and NO Copyright
    the Project is a PAL format all the way.. Using Philips DVD+RDL 8X Printable DVDs.
    I don’t think I have missed anything..
    I have tried to build and burn in DVDSP with no errors coming up. Also I tried to buld then burn from Tost 9 using the TS folder with NO Region code..
    Here is the problem I can’t play the DVD on my player Daewoo DVG9000N
    and on my friends player it takes for ever for the dvd to be recognized but it does play only I have had it jam in two places.. I have reexported using the same method in compressor because I found a video glitch (maybe I was asking my computer to do too much at one time)
    Now the DVD’s play in any computer I have tried and also a portable DVD player but still I need to know if there is something I’m missing in finding what home players DVDSP is compatible with..
    Any help would be greatly appreciated..
    Bryant
    Keith Troester replied 17 years, 11 months ago 3 Members · 2 Replies
  • Michael Sacci
    September 16, 2008 at 5:35 pm
    [Bryant Gover] “with NO Region code”
    I don’t have Toast 9 but are you really setting the disc to have NO region code? Most of the time this should be set to ALL or at least the one you are living in.
    I only used Verbatim DL disc, I tried a couple other brands and they didn’t work but that was years ago, I just stick with what I know works.
    What happens when you Build and Format the disc all within DVDSP? Do these disc work?
  • Keith Troester
    September 19, 2008 at 8:31 pm
    For maximum compatibility, I wouldn’t go higher than about 10 Mbps total bit rate (AV + MAX; audio is constant bit rate). This is what often causes (especially older) DVD players to not work or lag.
    Try lowering them and see what happens (at least 1 mb difference between the AV. + MAX., if using VBR).
    My Weekly Comic for TV Techs: https://fpscomic.blogspot.com
