Activity Forums DVD Authoring DVD+R or -R?
  • DVD+R or -R?
    Posted by Jeffdriscoll on June 9, 2006 at 3:00 am
    I’m gearing up for my largest production yet and it’s the first one where I”m dealing with actual clients and buyers and not friends / family who have easy access to me if there’s a problem, so I’m being careful about all my steps.
    Now I’ve always been told to use DVD+R discs to get most DVD players to work with the discs, but the person who contracted me says he’s always heard to use DVD-R.
    IS there one that’s better than the other? Is there any difference really? Why the confusion?
    Supervideo replied 20 years, 2 months ago 4 Members · 6 Replies
  • Wts(jmanz)
    June 9, 2006 at 11:57 am
    You’ll probably get as many opinions on this as people you canvas for an answer. If you ask the question on a Mac forum, most would lean towards (-) media; on the PC side it’ll be split down the middle. The first Mac’s didn’t allow for burning (+) media, but they all do now.
    This is my opinion. With today’s set top players, they both perform well. If you are outputting to single layer media, the (-) media has an edge. The reason for that is that there are still some players that won’t read the (+) discs unless the bit setting is set to ROM (which not all burners and or burning software can do). If you have a burner that does the above (and the software to set it); then the (+) media should work just as well.
    With dual layer projects, the advantage goes to (+) media. In fact, I would recommend NOT using (-) media for anything other than using it as a means for optical storage of data. The (-) does not work well at all for dvd video.
    Jim
  • Bob Cole
    June 9, 2006 at 8:37 pm
    [WTS(JManz)] “The (-) does not work well at all for dvd video.”
    Jim, I’m told by duplicating houses to use DVD-R for my (single-layer) authored DVDs. What is it I am missing here?
  • Wts(jmanz)
    June 9, 2006 at 9:50 pm
    I’m not sure about your question, but I’ll take a stab at it. I’m assuming you didn’t note the beginning of that paragraph? My reference was in regards to dual layer recordable discs and playback on set top players. The (-) media is clearly inferior in this regards. I think (-) media has a slight edge over the (+) media for single layer projects and playback on set top players.
    With all of that said, how any particular disc performs on a given set top player is independent of how a replication facility would prefer to have the project delivered.
    Jim
  • Bob Cole
    June 11, 2006 at 12:16 am
    [WTS(JManz)] “I’m assuming you didn’t note the beginning of that paragraph?”
    You are right. Thanks for the reply. I should have read your post more carefully.
    — Bob
  • Wts(jmanz)
    June 11, 2006 at 12:26 am
    Bob,
    No need to apologize, I’ve done exactly the same thing.
    Jim
  • Supervideo
    July 5, 2006 at 9:13 am
    if you want all your discs to play on any player 100 percent ..you must use 3.95 dvd s made for authoring …and they can only be burned on the pioneer 201 burnner
