Activity Forums DVD Authoring DVD/BLURAY Workflow Issues
  • DVD/BLURAY Workflow Issues
    Posted by Luca Schaumkessel on June 2, 2014 at 2:52 pm
    Hello!
    Im searching for a simple way, using as few as possible programs (best only one) to author a 5.1 DVD or 5.1 Bluray, starting with a ProRes 444 Fileout with 6 Audio Channels.
    I create a reference film of the ProRes Fileout in Quicktime without Audio, in order to import into Adobe Encore (Encore does not support video files with more than 2 audio channels). Then I have to create a 5.1 AC3-File in Compressor, using the ProRes Fileout as Source for the Surround Sound (L;R;C;LFE;Ls;Rs).
    Afterwards I import the AC3-Audio into Encore too and start authoring.
    There must be an Authoring software, which is capable of importing ProRes 4444 with 6 Channel and transcoding into proper Video for DVD/BLURAY (MPEG-2/MPEG-2 or H264) and 5.1 AC3 (maybe another established format?) in the right (or rather original – like source- )channel order .
    Any ideas? Any professional Software recommended?
    As you can see there is a solution but we are searching for a simple workflow for everybody (not only technology affine people).
    Kind regards
    Luca
    Andreas Gumm replied 12 years, 3 months ago 2 Members · 1 Reply
  • Andreas Gumm
    June 2, 2014 at 5:57 pm
    Professional tools expect usually already encoded elementary streams. 😉
    For PC world I would suggest DVDlab.
    It also needs preencoded elementary streams, but it creates professional results.
    Andreas
    Andreas Gumm
    selfemployed media author
