Activity Forums VEGAS Pro DVDA5 Crop and Adjust
  • DVDA5 Crop and Adjust
    Posted by Pete Locascio on January 30, 2009 at 8:24 pm
    I can get all of the features in the “crop and adjust ” dialog of DVDA5 to work, except the “colorize” feature. Any Ideas? Thanks!
    Rob Strobbe replied 17 years, 7 months ago 2 Members · 1 Reply
  • Rob Strobbe
    January 31, 2009 at 2:27 am
    There are two ways to pick a color for the Colorize setting:
    1. Click on the “color bar” (I guess you would call it), which brings up a basic color picker. When you use that, the Alpha value of the color will be set to 255.
    2. Select the Colorize setting and then click the dropdown arrow to bring up a more advanced color picker. The rub with this second one is that, even if you click color, it doesn’t set the Alpha value automatically. So the value remains at 0 (transparent). To change the value, type a new one (between 0 and 255) in the “A” box or use the arrow / line in the Alpha picker on the left.
    Rob
