Activity › Forums › VEGAS Pro › DVDA4 question – how do you fade up buttons?
  • George Wing
    February 11, 2007 at 4:01 pm
    Do you want them to “Transform” gradually from small to normal size? or do you want them to gradually fade in from invisible to visible? or do you want some other effect?
    The first effect can be done using the TRANSFORMATION tool in DVDA4.
    The 2nd option can be done by creating a motion menu that includes the buttons fading in, and then changing the LOOP-POINT for the menu. Add some buttons over the “existing buttons” in the video you prepared, and change the highlight style — maybe make them an UNDERLINE to start with until you figure out how to get external subpics using shapes…
    Regards,
    George
