Activity Forums VEGAS Pro DVDA4 – Cinescore loop point
  • DVDA4 – Cinescore loop point
    Posted by Jacob Hobbs on September 7, 2007 at 11:21 pm
    I’ve run into a limitation of using Cinescore within DVDA4. I created an animated menu with a loop point within DVDA. Then I added some generated music to the menu.
    The problem is DVDA doesn’t allow audio to be adjusted. You can’t move the audio file on the timeline nor create transitions. So you can’t create a seamless audio loop.
    Sony needs to consider adding more functionality to DVDA.
    Terje A. bergesen replied 18 years, 12 months ago 2 Members · 1 Reply
  • Terje A. bergesen
    September 8, 2007 at 6:56 am
    Seems to be what is coming in DVDA 4.5
