Activity Forums VEGAS Pro DVDA3 Setting thumbernail time problem
  • DVDA3 Setting thumbernail time problem
    Posted by Hanseric28 on August 10, 2005 at 12:11 pm
    I am trying to enter a time for the thumbernail image instead of dragging the handle. when entering 00:00:41:12 it jumps to the end of the video file. if entering 041 it jumps to approximately 40 seconds. If entering 41 it jumps some where else. If entering 150 it jumps to some thing like 3 minutes.
    Does any one know the logic behind this problem?
    Hanseric28 replied 21 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Jay Allen
    August 10, 2005 at 3:08 pm
    I have a simular problem. useing the arrow keys to advance to the proper frame for the thumbnail i want..instead of moving frame by frame it jumps from 17-40 sec depending on which computor i use. I posted this problem and got the usual…hold down the control key while useing the arrows – i have tried holding down just about every key to the same result. I have also expanded the view to frame view and this diddnt help either.
    Still confused
    J
  • Edward Troxel
    August 10, 2005 at 3:43 pm
    Try holding down the CTRL key and dragging the adjuster with the mouse.
    For me, typing in timecode is also working.
    Edward Troxel
    JETDV Scripts
  • Jay Allen
    August 10, 2005 at 4:34 pm
    Holding control while dragging mouse works frame by frame!!!
    I never tried that combo. Would like to see the arrow methoud fixed.
    Thanks again Edward.
    Jay Allen
  • Hanseric28
    August 11, 2005 at 5:34 am
    Jeditdv: I am using 3.0a and I have not tried 3.0b yet but are you entering the time code in some special way? The way I am doing it is moving into the time code and changing. When pressing enter it usually changes the time code to the last frame in the mpeg file. Which version are you running?
  • Hanseric28
    August 11, 2005 at 11:36 am
    I have now tested some more. Holding down ctrl helps allot when dragging the handle. When I am entering a time code in Button properties – Media – Thumbnail – Start time. 100 will give me the time 00:01:40:00(100 sec). 90 will give me 00:00:03:15 (90 frames). 090 will give me 00:01:33:15 (?) the only logic might be if 00:01:30:00(90sec) + 00:00:03:15 (90 frames). 03000 will give me 02:50:00:00 (?) 3000 will give me 00:50:00:00 (3000sec)
    Is it only me or does some one else have this problem?
  • Edward Troxel
    August 11, 2005 at 1:36 pm
    I’m looking at DVDA3.0b. I just entered 100 and got 00:00:01:00. I entered 090 and got 00:00:03:00. I entered 12345 and got 00:01:24:15 (which makes sense since 45 would be 30+15). Entering 4000 I got 00:00:40:00.
    One other thing: I’m on NTSC.
    Edward Troxel
    JETDV Scripts
  • Hanseric28
    August 12, 2005 at 5:09 am
    I will try 3.0b.
    Thanks for your input.
