Activity Forums VEGAS Pro dvda3 problem
  • dvda3 problem
    Posted by Martin Boulianne on March 23, 2006 at 2:07 pm
    I’ve been having a strange problem lately..
    Every time i try to prepare and burn a progect…DVDA3 keeps crashing and shuting off…??
    i have a P4 3.4, 1 gig ram, 3 data HDs a 250 gig 2 200, and an 80 gig for the system.
    I have reinstaled my old DVDA 2.0 and still have the same problem.
    all that is in the progect is 3 30 min vids in .AVI with a simple menu.
    HELP!!!! i’m 3 weeks behind in DVD burning!!!
    Martin
    Tom Pauncz replied 20 years, 6 months ago 4 Members · 4 Replies
  • Donatello
    March 23, 2006 at 3:30 pm
    are the prepare folders on a drive that are on a ATA/sata pci card ?
    if yes – try changing the prepare folder to a drive on the mother board.
  • Martin Boulianne
    March 24, 2006 at 4:13 pm
    The mother board has 4 Sata drives…3x 200gig and 1x 250gig
    and on the main IDE i have a 80 gig and a LG DVD burner
    Martin Boulianne
    Tech.dir.
    Mont-Tremblant
  • Jeremy Rochefort
    March 24, 2006 at 4:55 pm
    Are you preparing to the same drive? Try preparing to another physical hard drive.
    Something tells me theres something not quite cool with your driver setup/configuration
    Cheers
    Jeremy
    MJ Productions
    MJ Productions
  • Tom Pauncz
    March 25, 2006 at 5:13 pm
    Martin,
    First, I assume, that you have used DVDA3 successfully before. Right?
    Other than the suggestions already made, I’d check out the cooling fins on your processor by opening the computer case and looking. There have been various strange crashes reported with both Vegas and DVDA due to overheating processors.
    HTH,
    Tom
