Activity Forums VEGAS Pro DVDA3 – error on make disc
  • DVDA3 – error on make disc
    Posted by Brian Peacock on July 18, 2006 at 11:53 pm
    Can anyone help?
    I set up my menu, preview works perfectly, but when I want to go ahead and prepare the disc I get an error.(immediately; – DVDA then shuts down)
    I have tried a simple one clip test, made new temp files on a disc with heaps of room, checked all settings (PAL), made sure the sound and video clip has the same name, even reinstalled DVDA.
    Can anyone suggest what else I can do to get it working?
    It was OK – I rendered/prepared a disc overnight in DVDA and it gave an error – I initially thought it was a disc space problem but nothing I do can get it to work.
    Brian Peacock replied 20 years, 2 months ago 2 Members · 2 Replies
  • Jim Murphy
    July 19, 2006 at 2:29 am
    Brian, have you had this problem before, or is this the first time you are trying DVDA3?
    When you click on “Make DVD,” are you then clicking on “Prepare,” or “Burn”? I have had better luck using “Prepare,” then burn the DVD from a program like Nero. (I use RecordNow Max.) Good luck! Jim
  • Brian Peacock
    July 19, 2006 at 10:50 am
    Hi Jim,
    I tried both options with the same result. I had a similar problem before – but that bombed out half way due to insufficint disc space. This time it bombs out after “thinking” for a few seconds.
    regards
