Activity Forums VEGAS Pro DVDA won’t stay registered
  • DVDA won’t stay registered
    Posted by Paul Goelz on January 3, 2010 at 1:48 am
    I recently purchased the downloadble Vegas Pro 9 and DVDA Pro 5 as an upgrade from the Studio versions. Vegas installed and registered just fine but DVDA would not register until Tech Support walked me though a slightly different registration procedure. After that it worked OK for a week or two. Then suddenly today DVDA wants to register again when I try to start it. I have changed nothing in the PC. But now when I start DVDA I get a box stating that “registration may require elevated privileges”. When I click OK, it just dies and returns to the desktop. Interestingly, if I go to the DVDA folder in Program Files and set the DVDA executable to “Run As Administrator”, DVDA starts fine after clicking OK in the UAC window.
    Any ideas before Monday when I can call tech support? I tried searching and didn’t find anything relevant….
    Paul
    Paul Goelz replied 16 years, 7 months ago 2 Members · 5 Replies
  • Steve Rhoden
    January 3, 2010 at 2:32 am
    Im just here kinda pondering if you have a trojan/virus etc
    on your system, that maybe is kinda causing this and other issues.
    Do a thorough scan of things, i usually recommend “malwarebytes”
    You would be surprised at some of the things these pests throw
    out of whack on your system.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
  • Paul Goelz
    January 3, 2010 at 2:36 am
    I guess that is a possibility. But I’m pretty cautious, I have a virus scanner running in real time, and I don’t have any other issues. I’m rendering something right now. When it is done, I’ll run a scan. Note though that Vegas continues to run just fine. It is just DVDA that has an issue. They were both installed at the same time.
    Paul
  • Paul Goelz
    January 5, 2010 at 1:09 pm
    A scan found nothing. Neither did Windows Defender.
    I called Sony and they can’t figure it out either. An uninstall uninstalls cleanly and a re-install installs OK but produces the same symptoms…. unless you set it to “run as administrator”, DVDA thinks it is not registered but the register process just dies instead of completing. When set to “run as administrator”, DVDA starts and runs normally. Vegas runs normally at all times.
    I sent my system specs to Sony and they will supposedly get back to me.
    In the mean time I found another thread that suggests that maybe terminal services is not running. I’ll have a look tonight.
    Compared to my laptop (which runs DVDA perfectly), there are no differences that I can see in the permissions or folder contents for DVDA. I also looked through the registry and didn’t find anything suspicious.
    One oddity that may or may not be related…. I used to run Vegas Movie Studio Platinum bundle. While that was installed, I downloaded a copy of DVDA Pro 5.0 and installed it in trial mode. When the trial expired, I uninstalled it. When I upgraded to Vegas Pro, the Studio versions were still installed. Vegas Pro installed normally but DVDA installed to the DVDA 4.5 folder that was occupied by DVDA Studio 4.5. When I noticed this, I uninstalled ALL Sony products, deleted all folders and then re-installed. Ever since then, DVDA says it will install to a DVDA 5.0 folder but actually creates and installs to a DVDA 4.5 folder in Program Files (x86). Not sure if this means anything or not. DVDA DID work normally for a couple weeks…. this registration issue just started a couple days ago.
    Paul
  • Paul Goelz
    January 8, 2010 at 11:44 am
    Well, Sony doesn’t seem to have any ideas why this is happening. DVDA starts without incident if I boot into safe mode but in normal mode it thinks it is not registered unless I run it as administrator. I have carefully looked at the permissions for the executables and the entire Sony folder tree and compared them to the permissions on my laptop (which works normally) and I don’t see any differences.
    I have asked Sony several times what is involved when DVDA determines whether or not it is registered and they have not answered. I understand why they might be reluctant to explain it, but I am at an impasse here. Does anyone have any insight into how DVDA determines whether it is registered? That would be the place to look.
    I can always run it as administrator, but I shouldn’t have to and it bugs me 😉
    Paul
  • Paul Goelz
    January 19, 2010 at 11:50 pm
    For anyone else researching this issue…..
    After a great deal of communications between me and Sony, they now say they can duplicate the registration issue and there will be a fix forthcoming some time in the (unspecified) future.
    Paul
