Activity Forums VEGAS Pro DVDA, why can’t I burn a 4.61 GB file?
  • DVDA, why can’t I burn a 4.61 GB file?
    Posted by Donlao on February 8, 2006 at 5:11 pm
    Hi folks, I have a question concerning DVD creation on DVDA. I thought I should be able to burn files onto dvd media that is 4.7gb, or less since my file is only 4.61 after creating Mpeg2 plus menu. This is my first time creating a dvd on DVDA, although, I’ve had VegasDVD for several years. Any suggestions on this, should I go back and rerender a shorter Mpeg file?
    Stephen Mann replied 20 years, 7 months ago 4 Members · 4 Replies
  • Edward Troxel
    February 8, 2006 at 5:21 pm
    Because a “4.7Gig” dvd is really 4.37Gig in size?
    It’s a difference between base 10 (which humans use) and base 2 (which computers use). It’s a little misleading.
    Edward Troxel
    JETDV Scripts
  • Donlao
    February 8, 2006 at 8:34 pm
    Oh, I see. Thanks alot Ed..
  • Peter Wright
    February 9, 2006 at 12:23 am
    It’s also used as an exaggeration by manufacturers to make their hard drives/discs sound bigger than they are!! e.g. “120 Gb Drive” is really 112.
  • Stephen Mann
    February 9, 2006 at 8:35 am
    The disk manufacturers will have to start explaining themselves better because when people start installing 500Gb drives and only seeing a little over 400Gb after formatting, they are going to hear from them. Maybe they should start putting the approximate *formatted* drive size on the box?
