Activity › Forums › VEGAS Pro › DVDA slow
  • DVDA slow
    Posted by Martin Phillips on November 3, 2009 at 11:41 pm
    Sorry if this us a stupid question. I have noticed that when I open dvda and bring in the footage it’s luke working in mud – slow, slugish. If I hit a point on the time line the preview take a few seconds to catch up. Preview is jumpy. Is this because dvda is loading the footage – if so is there a way of seeing progress. Thanks Martin.
    Theo Van laar replied 16 years, 10 months ago 2 Members · 5 Replies
  • Theo Van laar
    November 4, 2009 at 12:38 pm
    What kind of files are you loading into DVDA?
    Theo
  • Martin Phillips
    November 4, 2009 at 12:43 pm
    Hi Theo,
    The footage is edited in 1080i and rendered out of vegas 9 as standard DV… ie mpeg 2 Video: 25 fps, 720×576 Upper field first, YUV, 6 Mbps
    Pixel Aspect Ratio: 1.457…
    Regards
    Martin
  • Theo Van laar
    November 4, 2009 at 12:49 pm
    A standard DVD PAL (720 x 576 px) is lower field first and RGB.
    Theo
  • Martin Phillips
    November 4, 2009 at 12:58 pm
    Hi Theo,
    Thank you for your response – and having looked at the standard template for PAL dv it is lower first – the footage is upper first as captured, so i assumed it would be better to stick to that field order. Sorry, but i don’t understand the RGB?
    Are you saying that DVDA is having to re render to lower field first ? and therefor i should render from vegas lower field first.
    Regards & thanks
    Martin
  • Theo Van laar
    November 4, 2009 at 1:58 pm
    ‘Are you saying that DVDA is having to re render to lower field first ? and therefor i should render from vegas lower field first.’
    Yes, that’s what I was thinking of.
    Theo
