Activity Forums VEGAS Pro DVDA render is taking an age.
  • DVDA render is taking an age.
    Posted by Martin Phillips on February 7, 2010 at 11:26 pm
    Hi, I guess I must br doing something wrong. But a project (just over 1hour in length). Shot in HDV, rendered our in Vegas as DVD mpeg 2. Yet when I bring it into dvda it has so far taken 1 hour on the render section of burning the disc
    martin
    Mike Kujbida replied 16 years, 6 months ago 2 Members · 1 Reply
  • Mike Kujbida
    February 8, 2010 at 1:48 am
    If you didn’t render it as separate streams (MPEG-2 & AC-3) at the proper bitrate settings using the DVD Architect NTSC (or PAL) Architect video (or widescreen) stream template, then DVDA has to re-encode it and this would take considerable time.
    Typically a 2 hr. SD project that I’ve encoded from Vegas takes around 10 min. to Prepare in DVDA.
