Activity Forums VEGAS Pro DVDA question
  • DVDA question
    Posted by Carlo Simone on August 29, 2006 at 3:33 am
    If I am using an animated background for a dvd menu, how do I get it to loop after the default 30 seconds. Everytime I add a song to the menu, it goes black after 30 secs..Thanks..
    Don Bloom replied 20 years ago 4 Members · 3 Replies
  • Edward Troxel
    August 29, 2006 at 1:26 pm
    You song also has to be 30 seconds long. OR you must make the video segment that loops as long as the song. BOTH must be the same length.
    Edward Troxel
    JETDV Scripts
  • Chris Franklin
    August 29, 2006 at 2:42 pm
    “you must make the video segment that loops as long as the song. BOTH must be the same length.”
    There’s got to be something other than that, because I also have the same problem, and both Audio and Video tracks are the same length. (I render both tracks from Vegas with the same in and out points.)
    I got it to loop only one time (my first time on DVDA!!), and I can’t for the life of me figure out how to do it again.
    My problem is that after the background plays through all the way, it freezes on the last frame and does not loop.
  • Don Bloom
    August 29, 2006 at 2:56 pm
    Try END ACTIONS in the menu-set to LOOP- that should solve the situation.
    Don
