Activity Forums VEGAS Pro DVDA Project Properties – Audio Bit Rate
  • DVDA Project Properties – Audio Bit Rate
    Posted by Bob Linsdell on July 1, 2011 at 2:49 pm
    In my Blu-ray project I have audio files with bit rates higher than DVDA’s AC-3 default of 192Kbps. What bit rate would you recommend, or have chosen to use in your projects?
    Thanks in advance.
    John Rofrano replied 15 years, 2 months ago 3 Members · 2 Replies
  • Stephen Mann
    July 2, 2011 at 5:31 am
    I am pretty certain that the Blu-Ray spec only goes up to 192Kbps. Most Hollywood titles only use 24-bit/48Kbps.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • John Rofrano
    July 2, 2011 at 2:01 pm
    If you create your AC3 files in Vegas Pro you can go above 192Kbps but I’ve never tried that. I don’t have any issues with 192Kbps. Bit rate alone is not the whole story. The encoding has a lot to do with how good something sounds at a particular bit rate.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
