DVDA Picture Compilation Background
Posted by Antoine Guy on August 10, 2012 at 12:42 pmHi All
I have a picture compilation in DVDA. Because I choose to Letterbox for my images, invariably I will have black bands at the sides. I wish that these ‘bands’ are purple. ie I want a widescreen purple background to my compilation. DVDA wont let me add another video track. (I wanted to then take a purple background and put it above the images track). Is there anyway I can achieve this?
Many Thanks
Antoine
Antoine Guy replied 14 years, 1 month ago 3 Members · 16 Replies -
Andrew Lenczycki
August 10, 2012 at 3:21 pmI don’t believe you will be able to do that from within DVDA.
1) You will have to go back into Vegas and setup your project to be Widescreen (16:9) in your project properties.
2) Put a Generated Media solid color (purple) onto your bottom track.
3) Put your pictures on a track above this.
4) Don’t set your pictures to match aspect ratio in the Pan/Crop area, which will leave them as standard (4:3) layout.In essence, you will create a widescreen project (with a purple background), that has standard (4:3) format pictures displayed in the center of this.
Andrew Lenczycki
Andrew Lenczycki
August 10, 2012 at 3:26 pmShould be no “fear”, just go back to your Vegas project and make the few changes noted and you should be good to go.
Andrew Lenczycki
Antoine Guy
August 10, 2012 at 3:36 pmActually, i’m having a few problems with some photos which need rotation. In DVDA this was simple – you just pressed the rotate icon.
In Vegas this is proving a bit trickier. I go into pan/crop and as you suggested I make sure the maintain aspect ratio is set to no. I then type eg 270 degrees in angle of rotation. However, Vegas seems to keep the width constant, resulting in the top and bottom being cropped. Any ideas? -
Mike Kujbida
August 10, 2012 at 3:40 pmI rotate my pictures before I bring them into Vegas using IrfanView (a great app that’s free!!).
If they’re in portrait mode, then you will have to do some cropping as they won’t fit a 4:3 or a 16:9 screen. -
Antoine Guy
August 10, 2012 at 3:42 pmSure, I realise I can rotate before import, and I may well have to do that. But is there not any way in Vegas equivalent to the rotate function in DVDA? (by the way, I’m happy to letterbox)
Antoine Guy
August 10, 2012 at 3:48 pmActually, even if I rotate before import, Vegas will not show the whole image because it appears to want to use a constant width!
Mike Kujbida
August 10, 2012 at 3:49 pmPan/Crop is the best way to do this in Vegas.
Rotate the first desired image in Pan/Crop but don’t do any other cropping to it just yet.
Copy the image.
Click on the next one to select it, right-click and select Paste Event Attributes.
You can select multiple images to do this to a bunch of them at the same time. -
Mike Kujbida
August 10, 2012 at 3:50 pmVegas brings events in according to your project properties and scales/displays things according to those settings which is why Pan/Crop is almost mandatory.
Antoine Guy
August 10, 2012 at 3:54 pmI tried this before but it doesn’t work. I’m not interested in cropping at all. I entered the angle of rotation in pan/crop, but Vegas auto crops the image after rotating. As I mentioned earlier, this seems to be because Vegas will not allow images of less than a certain width.
Just to clarify – I’m trying to rotate a landscape into a portrait without losing aspect ratio and without cropping – obviously the image will be smaller, but I’m happy with this. Another way of describing this is that I want to do exactly what the rotate image icon does in DVDA.
Rotating before import does not work either! Very strange….
