Activity Forums VEGAS Pro DVDA not linking audio from SV 64bit Project
  • DVDA not linking audio from SV 64bit Project
    Posted by Brandon Brand on November 3, 2009 at 4:29 pm
    Hi All
    I’m running a dual boot system, one with Windows xp 64bit and SV Pro 8.1. And the other Windows XP 32bit with SV Pro 8.0 and DVDA
    My problem is that i did a project in the 64bit version of Vegas rendering the video as mpeg2 with no audio, and then rendered the audio with the ac3 format knowing that i have to keep the file names the same. I Then booted back into my 32bit version where i have DVDA installed. DVDA does not seem to link the video with the audio. I’m i missing a step?
    Please help i have deadline! 🙁
    Thanks in advance
    Brandon.
    Mike Kujbida replied 16 years, 10 months ago 2 Members · 3 Replies
  • Mike Kujbida
    November 3, 2009 at 4:33 pm
    I’m not a 64-bit user yet so I can’t answer why it’s not working for you.
    This is an easy fix though as all you need to do is to load in the MPEG-2 file and then drop the AC3 file on the DVDA timeline under the MPEG-2 stream.
  • Brandon Brand
    November 4, 2009 at 5:37 pm
    Thanks Mike
    It worked perfectly! I’m so pleased. You guys are real pros…
  • Mike Kujbida
    November 4, 2009 at 6:00 pm
    Brandon, I’m very glad to hear that it worked for you.
