Activity Forums VEGAS Pro DVDA Burn issue
  • DVDA Burn issue
    Posted by Martin Phillips on August 1, 2012 at 3:33 pm
    I am running the latest Vegas 11 pro and DVDA. I am burning a 3 hour film to a duel layer bluray disc. The project has rendered out of Vegas fine, the DVDA project looks fine, up until I try to burn the disc – firstly, I noticed DVDA didn’t ask me about layer break point, and secondly it said there may not be enough room to create the temp image….. the burn failed.
    I eventually worked out the no room issue, I have reset the folder to default in the properties and there wasn’t enough space for the 38gb film. DVDA still doesn’t ask for a break point, I have burned 1 bluray successfully, but the 2nd copy just won’t complete, it gets to about 40% and freezes, no flashing on the burner. I have as part of my attempts to fix this replaced the burner, split the project and successfully burned 2 1.5 hour films.
    I think the issue is related to DVDA not asking me to select the layer break point…. I never had this before. I have also re installed DVDA and have just restored the PC system.
    Any help gratefully received.
    Martin
    Martin Phillips replied 14 years ago 2 Members · 2 Replies
  • Jeff Schroeder
    August 1, 2012 at 3:56 pm
    This might sound like a simple question, but, do you have chapter markers near the middle point (without the yellow warning flag)?
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Martin Phillips
    August 1, 2012 at 5:08 pm
    Hi Jeff,
    Yes threre are chapter marks throughout the film, at least 3 between 1.20 and 1.50.
    Regards
    Martin
