Activity Forums VEGAS Pro DVDA 3 switching video
  • DVDA 3 switching video
    Posted by Chase Mccullan on February 22, 2006 at 2:24 am
    So, I’ve made a compleate video setup with scene selectors and everything. I’m not very familiar with DVDA but I don’t think it should be to hard to do what I want to do. I’ve had to rerender my video due to some minor changes, but I’ve rendered it with the scene markers. The problem is, how do I now replace the old video/audio in my DVD layout and have everything recognize the new video as what I want to use.
    This is what I’ve tried alreay:
    -right click the main video and select replace, suddenly the DVD goes to 5.1 GB, where the video source was around the same at 2.3GB.
    -also, when delete the old one, the markers don’t get deleted with it.
    I’ve been playing around with no luck, please tell me what the best way is. Thanks
    Chase Mccullan replied 20 years, 7 months ago 2 Members · 2 Replies
  • Gary Kleiner
    February 22, 2006 at 2:39 am
    You also have to delete the file from the project overview to clear the disc overhead.
    In your situation, I would try renaming the original file (if you still need it), then name the revised file with the name the original one started as, so you “trick” the software into thinking it’s setting up the project with the same file.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Chase Mccullan
    February 22, 2006 at 5:28 pm
    Hi Gary, Thanks very much! I gave it a try and it actually worked.
