DVDA 2 Re-renders/compresses audio sometimes
Posted by Wayne Grauel on January 13, 2006 at 2:23 amon occasion, DVDA 2 will tell me that it has to re-reneder (or compress) audio on track 1 (or what ever).
I just let it do its thing, but can anyone explain why this would be – when it is already rendered as an AC3 file?
Thanks’
Wayne
Allen Zagel replied 20 years, 8 months ago 4 Members · 7 Replies -
Edward Troxel
January 13, 2006 at 2:53 am -
Wayne Grauel
January 13, 2006 at 10:13 amWow… ED, you may be onto someting,
if memory serves me (less and less as I get older) I seem to get this when I “apply effects to” audio tracks (EQ) – or perhaps filter or open audio tracks (or copies of audio tracks) in the wave editor (coold edit 2K) or copy or duplicate tracks. which then vegas often makes a “copy” of the track
Is there any thing special I should do to my audio renders to make sure everything is “as it should be” – or anyting to prepare int the time line?? -perhaps prerender the audio???
Old habits are hard to break and I really needed to keep production up so I still relyed on much of my editing on media 100’s (for the sake of learning curve) but I’ve tried to use vegas more and more lately so I perhaps have the cart way ahead of the horse in terms of “jumping ahead” with procedures without clearly understanding what I’m doing. (the program is proving to have some really strong points)
Any insight on the fact that one “monkeys” with the audio tracks and then DVDA2 ends up having to recompress something – when I do render for DVD i usually take these steps: 1. select all 2. render mpeg2, and then the AC3 at -31 db as suggested.
thanks all!
Wayne
Edward Troxel
January 13, 2006 at 3:43 pm -
Wayne Grauel
January 13, 2006 at 4:02 pm“That’s why I always double-check to make sure the AC3 is being used.”
Ed, how do i check that… thanks for your time!!!!
Thanks, Wayne
Wayne -
Edward Troxel
January 13, 2006 at 4:30 pm -
Mike Kujbida
January 13, 2006 at 4:32 pmWayne, make sure that you’re using the DVD Architect NTSC video stream to get a video only clip. Selecting anything else will give you either an m2v file or an mpeg file with audio.
Mike
Allen Zagel
January 14, 2006 at 11:43 amAs Mike says above. Then go back and render to AC3. You should then have two files. Your video and the audio. When you drag the video into DVDA-2 the audio will automatically follow.
Allen
My web site features;
China, China Railways and music.
https://www.azagel.comVideo site;
https://www.asxvideo.com
NEW! Shanghai MagLev DVD.
