Activity Forums Adobe Encore DVD DVD Zoomed-in issue. Overscan?
  • DVD Zoomed-in issue. Overscan?
    Posted by Marc Walker on December 13, 2016 at 5:49 pm
    Hi all,
    I have spent some time attempting to create high quality DVDs from HD FLV files using AME and Encore. But although I have followed every help guide, read the support literature and used logical sense, approx 10 pixels are missing vertically and approx 20 horizontally when I play it on a DVD player(I have tried 2 players/TVs with same result)(like a slightly zoomed-in effect).
    In Encore and WMP, it plays perfectly fine.
    This is the transcoded file:
    General
    Complete name : J:\Authouring DVDs\Disc 1\ZZ Top.m2v
    Format : MPEG Video
    Format version : Version 2
    File size : 2.02 GiB
    Duration : 57 min 12 s
    Overall bit rate mode : Variable
    Overall bit rate : 5 053 kb/s
    Video
    Format : MPEG Video
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=12
    Bit rate mode : Variable
    Bit rate : 5 053 kb/s
    Maximum bit rate : 7 000 kb/s
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 FPS
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.487
    Time code of first frame : 00:00:00:00
    GOP, Open/Closed : Closed
    Stream size : 2.02 GiB (100%)
    This is a VOB off the DVD(video info);
    General
    Complete name : G:\VIDEO_TS\VTS_02_1.VOB
    Format : MPEG-PS
    File size : 1 024 MiB
    Duration : 26 min 51 s
    Overall bit rate : 5 329 kb/s
    Video
    Format : MPEG Video
    Bit rate : 5 031 kb/s
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.485
    Time code source : Group of pictures header
    Stream size : 967 MiB (94%)
    More info:
    The first DVD player(Panasonic) is quite versitile with regards to settings. I use the component(R/G/B) output(576p) and the HDTV(Samsung) recognises it as 720 x 576p. I have tried different aspect ratio settings on both TVs and DVD players and the best/closest settings are:
    DVD Players: 16:9 (1.0x zoom)
    TVs: 16:9
    NOTES:
    – Curiously, I have two video-loop-buttons “(%)” in the Main Menu, and in those, the same slightly zoomed-in effect occurs on the video, even while previewing in Encore, but I think that is because I used a 1280×720 thumbnail of the original HD video. Just thought I’d mention that.
    – I used “Scale to Fill” during rendering, because of black lines on the sides.
    – This issue is very recognisable due to the logo in the top left of the screen being 1/3rd missing.
    – I am in the UK(i.e. PAL). But I wonder if a NTSC render would resolve this? Is this the kind of effect using wrong TV standards would cause?
    Thanks for any help,
    Marc
    Marc Walker replied 9 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
