Activity › Forums › Adobe Encore DVD › DVD won’t play on one Player
  • DVD won’t play on one Player
    Posted by __peter__ on January 16, 2008 at 7:10 pm
    Hello,
    I have a production that has been mass-Produced (or what do you call that) from a company and everything seemed to be fine.
    Now one customer bought one of those and it doesn’t play in their DVD Player. I checked that copy in mine and several others and the DVD works. So I thought ok, I’ll burn a single copy of the original Encore project for that customer.
    BUT SURPRISE: The same. I doesn’t play. Every other Disc they have play in their PLayer and EVEN other productions from us also do.
    To be more precise:
    The disc Auto-Starts correct, but when reaching the first menu after the intro there is no cursor to select. And a simple “Enter” Button, which should start the first movie, also doesn’t work.
    So I have no more idea and I am worried that that could happen again with future products.
    Does anyone know of incopatible DVDs from Encore.
    Peter
    Xxx Xxx replied 13 years, 8 months ago 4 Members · 3 Replies
  • Mike Velte
    January 16, 2008 at 7:43 pm
    Likely a media incompatibility. Try a different brand and also try a + if you gave them a -.
    https://www.video2stream.com
  • Brian Nichols
    January 22, 2008 at 4:58 pm
    Maybe its the same as my problem. First play is unrecognized by my Sony settop DVD recorder. Works on any player I can get my hands on though.
  • Xxx Xxx
    January 7, 2013 at 7:17 pm
    I’ve had some problems with my customers playing DVDs too… did you ever get a solution to your problem?
    I use Encore CS5.1
