Activity › Forums › Avid Media Composer › DVD won’t play after output
Posted by Peter Ovens on November 13, 2009 at 2:20 ama second post to my first regarding the DVD. I took it to 2 other comp’s and it won’t play. but it does on the comp I burned it from.
Peter Ovens
Peter Ovens replied 16 years, 10 months ago 3 Members · 5 Replies -
John Cuevas
November 13, 2009 at 3:44 pmCould be a few things. First thing I would check, do those computers have the correct software to play a DVD? Not all computers are pre-installed with DVD software.
Is this a regular DVD, ie…one that will play in a set top player, burned through sonic or encore or a data with and you burned a mpeg, wmv or avi file? That could be a codec error.
Johnny Cuevas, Editor
http://www.ckandco.net -
Peter Ovens
November 16, 2009 at 2:45 amI have tried thru sonic free trial as an mpeg and the other computers in the house won’t play it.
the client can’t import it to play in Vegas 8 or Quick time.Peter Ovens
John Cuevas
November 16, 2009 at 1:55 pmI don’t know about Vegas, but QT doesn’t play DVD’s. The MPEG is transcoded and the files are converted to VOB’s on the disc. First check and see if this DVD will play in a standard DVD player. If it does than you know that it’s been burned okay, and the issue is the computers that are trying to play it. Try playing a store bought DVD in those computers-anything. It sounds like the computers just don’t have a DVD player installed.
Steve Schroeder
November 16, 2009 at 9:29 pmOne other thought – Did you finalize the DVD? Is that an option on your burner? I’ve had standard DVD-R that had to be finalized before they would play on any other player. Not so for DVD-RW.
Peter Ovens
November 18, 2009 at 9:23 pmI have finally got it to work, I had settings wrong and this time I exported in qicktime reference DV codec. the export setting was on Fast-Export Quicktime NTSC.
also I sent it to sorenson squeeze and burned it there.
thanks for all your helpPeter Ovens
