Activity Forums Adobe After Effects DVD turned yellowish
  • DVD turned yellowish
    Posted by Randall Murphy on August 28, 2007 at 4:06 am
    I have a video clip rendered from AE at lossless for windows video setting…looks great. (about 80 gigs) and then after making a DVD with encore, the skintones turned yellowish. Is there a specific translation setting I should put encore on or should I correct this in AE beforehand. If so, I’m not an expert at color correction, how can I tone down the yellows?
    Randall Murphy replied 19 years ago 2 Members · 3 Replies
  • Malcolm Desoto
    August 28, 2007 at 5:22 am
    Is it yellow after watching it on a TV? If so, your monitor is probably not calibrated correctly. If you don’t have a True Color or Broadcast monitor, than you can get your computer monitor fairly close by using color bars.
  • Randall Murphy
    August 28, 2007 at 11:39 pm
    I’ve heard people saying using colorbars (I’m probably looking like a real newbie here) Who do you use colorbars???
  • Randall Murphy
    August 28, 2007 at 11:47 pm
    I found that if I hit “autocolor” it made it look a lot better. Is this for more inexperienced users?
