Activity Forums VEGAS Pro DVD to wmv question
  • DVD to wmv question
    Posted by Doug Lewis on January 8, 2008 at 2:23 pm
    I have a DVD that I want to post on my website for others to see. No copyright involved. Is there a way to convert from the DVD format into something like Windows Media Video? I have Vegas 5 and DVDA. Let me know if Vegas will do it or if I need some other software. Thanks.
    Doug Lewis replied 18 years, 8 months ago 2 Members · 2 Replies
  • Jean-luc Oudin
    January 10, 2008 at 8:46 am
    Here’s something you can try.
    First, since you have no copyright issues, copy the VIDEO_TS
    folder from the DVD to your hard drive ( it will speed up
    the process ).
    Go to the following site and get VirtualDub-mpg ( while you’re
    there, you might also want to get the AC3-ACM codec ). BTW, they’re both free.
    https://home.comcast.net/~fcchandler/stable/index.html
    VirtualDub doesn’t need to be install. Just unzip the folder, I usually put it in the program files folder and create a shortcut for “virtualdub.exe” on my desktop.
    In Virtualdub, go File-Open video file, navigate to the VIDEO_TS folder and and open any one of the VOB files. Once the file is loaded go Menu Video-Compression ( or Ctrl+P ), select a compressor and then go Menu File – Save as AVI. Do the same for all the VOBs.
    You should be able to import the avi files into Vegas and render them in any format you want.
    Hope this helps.
  • Doug Lewis
    January 10, 2008 at 11:00 am
    Thank-you for the advice, I’ll give it a try.
