Activity › Forums › Apple Final Cut Pro Legacy › DVD to prores problems
  • DVD to prores problems
    Posted by Adrià Sunyol on January 5, 2013 at 3:27 pm
    Hi everyone:
    I’m having a problem: Converting some old footage in DVD to Prores for editing it in FCP7, it happens that, when i open the DVD using VLC, the time counter stops wen the video reaches 52 seconds, but the image continues till the end of the footage, with the time stoped at 52 seconds. Then, when i use Streamclip to convert, it only converts the first 52 seconds (it’s a short clip, a couple of minutes, but i need it all…)
    Is there any possible solution or i should go to the source of the dvd and ask for another copy?
    Thanks in advance,
    Adrià
    Rafael Amador replied 13 years, 8 months ago 2 Members · 3 Replies
  • Rafael Amador
    January 5, 2013 at 3:37 pm
    VLC is a player, not the proper application to make any kind of conversion.
    Use MPGStreamclip and convert the audio to PMC 48Khz, so can be edited in FC without recprocessing.
    rafael
    http://www.nagavideo.com
  • Adrià Sunyol
    January 5, 2013 at 4:21 pm
    I haven’t explained muself correctly: I am already usinf Streamclip, but it seems it is not recognising the footage without timecode…
  • Rafael Amador
    January 6, 2013 at 3:08 am
    Hi Adria,
    OK.
    Are you traying to transcode directly from the disk?
    If so, try to copy the VOBs to your computer and run MPPGStreamclip on them.
    If you can copy the VOBs on your HD, them they may have some protection.
    In that case you will need to use MacTheRipper or so.
    rafael
