Activity › Forums › Apple Final Cut Pro Legacy › DVD to FCP
DVD to FCP
Posted by Bob Vick on October 27, 2005 at 9:10 pmI have video on a dvd of one of our News Anchor’s trip to Africa. The dvd plays in the G5 but not in our Panasonic DVD recorder. Says not supported. I used an extractor to take it off the dvd and now it’s on my raid. How do I use it in FCP?
b
Bob Vick sr promo guy @ ch3 wwmt tv, kalamazoo, mi
Jeremy Garchow replied 20 years, 10 months ago 5 Members · 11 Replies -
Shane Ross
October 27, 2005 at 9:22 pmWhat extractor did you use? What format are the files?
It is best to use either MPEG Streamclip or DVDxDV to convert the DVD’s VOB file to DV/NTSC clips.
Bob Vick
October 27, 2005 at 10:37 pmI used mac the ripper. I have downloaded MPEG stream and Apple’s Mpeg2 encoder (20bucks). It’s just a long process. I am coverting to a QT Cinewave file. BTW is FCP upper or lower field?
b
Chris Poisson
October 28, 2005 at 1:51 pmBob,
In my workflow, the only way I deal with media from DVDs is to capture through a player connected to my deck. Set capture to uncontrolable device.
Bob Vick
October 28, 2005 at 3:31 pmYEAH same with me, but as I pointed out in my original thread, the disc was “not supported” playing from our Panasonic recorder. It’s the only model we use here.
The clips play fine in Streamclip. It’s when I export as a QT or DV or AVI – Cinewave codec or uncompressed 8bit-10bit it all looks worse
b
Jeremy Garchow
October 28, 2005 at 6:08 pmUse Streamclip’s recommendation for using upper field first. It’s counterintuitive, and doesn’t make sense, but it works. notice how it says, use upper for all codecs except dv? Follow their advice.
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
ATTO 42XS <> Huge Systems 4105 Fibre -
Bob Vick
October 28, 2005 at 7:23 pmRigh but when I select the Cinewave codec, it selects a frame size in a pal format. Any ideas why?
b
Jeremy Garchow
October 28, 2005 at 7:31 pmIs the source footage of the DVD PAL? Perhaps that’s why your DVD player can’t read it.
Alexander Serpico
October 28, 2005 at 8:30 pmif you want uncompressed from MPEG Streamclip, u need to manually enter the frame size at 720×486.
if you check all apple and aja (io and kona) uncompressed presets, they as well are Lower Field First.
Bob Vick
October 30, 2005 at 9:28 pmYou know…I will have to say yes? The footage is from Africa.
b
