Activity Forums Adobe Encore DVD DVD Testing
  • DVD Testing
    Posted by Nick Patten on May 4, 2005 at 7:02 pm
    This is a bizzare problem that I’ve been encountering lately, I create a DVD with Encore, I test it on a standard DVD player (it works fine), then after sending it out my clients come back saying it doesn’t work in their DVD players. Has anyone had anything like this happen before?
    David Neumann replied 21 years, 3 months ago 3 Members · 3 Replies
  • Matthew Press
    May 4, 2005 at 8:08 pm
    Hi Nick,
    When making your final DVD to Disc. Go to Build DVD. Choose Make DVD Disc. I had the same problem, and this solved it. The only negative is that it takes a bit longer to burn the DVD. Hope this helps.
    Matt
  • David Neumann
    May 4, 2005 at 9:06 pm
    is there a better way to transfer to dvd with a tumnal menue without acomputer or the best way is a computer
  • David Neumann
    May 4, 2005 at 9:09 pm
    is there a way to make automatic evry five or six minutes a chapter point in encore dvd
