Activity Forums Adobe Premiere Pro DVD Template created in PS works in preview but not after burning?
  • DVD Template created in PS works in preview but not after burning?
    Posted by Tom J on March 26, 2007 at 9:17 am
    Hello there,
    I have looked through the forums, and haven’t really found anything to help.
    Actually I found a couple of threads that seemed to be on the right track and then nothing. Perhaps I overlooked something, it’s been a bugger of a day…
    I am using PPro 2.0 and Photoshop CS2 in WinXP. I created a template with the different layers for main title, play all, scene selection, next, prev, etc. I grabbed the .psd template for my project and it works just fine in preview mode, but as soon as I burn the DVD, the menu selections or highlights are disabled. I can’t navigate or select the menus, all I get is a “static” screen. The menu text is there, but no “selection” icon is visible. So I assume the menu is disabled somehow. I can play the DVD just fine by hitting play or enter on the DVD controller though.
    I thought about using an existing template and just changing the content and doing a Save As, but I got the same problem. I even thought about “legal colors” for the highlights or icons but that didn’t help neither. They are just not there on the DVD…
    What could’ve I missed???
    Any suggestions? :>)
    Thanks folks,
    Tom
    Cal Johnson replied 19 years, 5 months ago 4 Members · 6 Replies
  • Vince Becquiot
    March 26, 2007 at 10:46 pm
    It is my understanding that, unlike Adobe Encore, PP templates cannot be modified in PS.
    Vince
  • Steven L. gotz
    March 26, 2007 at 10:49 pm
    They can, but you have to be very, very careful not to disturb anything. Just change – one for one – images and text.
    Steven
    https://www.stevengotz.com
  • Tom J
    March 27, 2007 at 4:21 am
    Are you serious, you’ve got to be joking. A .psd file that cannot be edited without some sort of trouble, that bites. Talk about a workflow hurdle. I mean I know they are pre-made templates, but that’s just it, they are templates, one would think you should be able to modify them to some extent.
    [Steven L. Gotz] “They can, but you have to be very, very careful not to disturb anything. Just change – one for one – images and text.”
    I have tried this to no avail. And all I did was change the text, images and placement of menus. That’s it…
    So lets say I choose to modify one, and keep the layer structure in tact. In my previous versions I have paid close attention to the naming conventions for each layer and item. How do I use just 2 of the 4 menus that are in some of these templates. I.e. Play All / Movie, Scene Selection. vs. Play All, Scene Selection, Credits, etc.?
    I just want to use the first two menus and discard the others. Do I have to keep them in the file and turn off their visibility where they are at or can I delete them?
    Thanks for the feedback and help,
    Tom
  • Tom J
    March 27, 2007 at 8:09 am
    Ok so not only did Photoshop start behaving badly, but PPro upon opening the saved project crashed everytime. Something along the lines of “Sorry but Premiere has encountered an error and needs to shut down. We will attempt to save your file”. Then it closed. Note: I did see for a split second what appeared to be the DVD Layout Preview window before closing.
    Luckily this project was an easy one to recreate with 12 chapters.
    So I first tried to dump my Prefs and Cache, etc. and that didn’t help. In fact, things got worse. I then unistalled the entire suite and re-installed it (man was that fun…)
    I recreated the sequence, reloaded the DVD Template that I created the first time, and Voila! Everything works. And “YES” in case someone is wondering, the check box for “allow DVD with Menus” or whatever it’s called, was checked originally.
    Alright enough babble, I just thought explaining my situation would help future Grazers here :>)
    Thanks again for the help,
    Tom
  • Vince Becquiot
    March 27, 2007 at 3:24 pm
    Yep, I’ve had mixed success modifying templates as well. The first thing to remember is that you shouldn’t introduce new layers unless they are button objects, and a functional part of the menu. Also, make sure all highlights are still hidden. And, of course, make sure that you respect the (++),(+*) etc. symbols.
    Vince
  • Cal Johnson
    April 2, 2007 at 6:23 pm
    I just started playing around with trying to modify/create custom templates too (a friend of mine was asking how to do it). Doesn’t seem easy or straight forward. However, what is easy and straight forward is to make your own menus in Encore. Just wanted to say that Encore is really easy to use, its not a heavy, in-depth program that you have to spend months learning. I took a few days to go through it, and found it pretty simple to create great looking menus quickly now, even if I haven’t used the program for a few weeks, its easy to remember. I know this isn’t much help for those out there with only Premiere to work with, but if you’ve got Encore, you’ll find it much easier to make your own menus. I notice that Premiere Pro CS3 is going to include an integrated version of Encore, so that should make the work flow that much easier.
