Activity Forums Adobe Premiere Pro DVD stuttering in playback
  • DVD stuttering in playback
    Posted by Ruby Gold on July 5, 2005 at 5:33 pm
    I’m using PPro 1.5 to edit my production, and exporting it via Adobe Media Encoder for authoring in ULead DWS2. The export settings from PPro that I’ve used are:
    Codec: MainConcept MPEG Video
    Quality: 5.0 (high quality)
    TV Standard: NTSC
    Frame Rate [fps]: 29.97 drop frame
    Field Order: Lower
    Aspect Ratio: 4:3
    Frame Width [pixels]: 720
    Frame Height [pixels]: 480
    Bitrate Encoding: CBR
    Bitrate [Mbps]: 8.0000 (high quality)
    M Frames: 3
    N Frames: 15
    After authoring, I burned it on a Sony DRX 500-UL burner at 4x speed from DWS2. The DVD is stuttering some in playback in a few places on a couple different computers. Can anyone help me figure out possible causes for this and some fixes? I want the export/compression to yield the highest possible quality but to have the maximum stability for playing in a variety of set-top DVD/tv players as well as computers. Thanks for any help.
    Aanarav Sareen replied 21 years, 2 months ago 2 Members · 1 Reply
  • Aanarav Sareen
    July 5, 2005 at 6:21 pm
    A few reasons this could happen is a) due to the media b) due to the player. Also, 8.000 MPBS MIGHT be a little too high for some players. Try reducing the quality to 7 or so. That might help.
    1. What media are you using?
    2. Model #/Manufacturer of the DVD Player?
    Aanarav Sareen
    Adobe Certfied Expert, Premiere Pro
    https://www.asvideoproductions.com/video
