Activity Forums DVD Authoring DVD Studio Pro – Video Bitrate Too High
  • DVD Studio Pro – Video Bitrate Too High
    Posted by Micah Et on October 27, 2005 at 2:22 am
    When i attempt to burn a dvd with DVD Studio Pro, it says that the video bitrate is too high. Do you know how to solve this?
    Cheers.
    Eric Pautsch replied 20 years, 11 months ago 2 Members · 8 Replies
  • 8 Replies
  • Eric Pautsch
    October 27, 2005 at 3:59 am
    lower your bitrate!! 🙂 try to keep your bitrate below 6.5 with AC3 audio. Good luck
  • Micah Et
    October 29, 2005 at 1:05 am
    this may sound stupid, but how do you reduce the bitrate. Is it in my export settings from final cut, or in the dvd authoring program?
  • Micah Et
  • Eric Pautsch
    October 29, 2005 at 2:17 am
    When you export from final cut do it through compressor.
  • Micah Et
    October 29, 2005 at 2:20 pm
    Thanks for the feedback eric, perhaps you have one more little trick up your sleeve.
    I have exported the video as an mpeg2 using compressor to keep as much quality as possible, but when attempt to import it into DVD Studio Pro it says it is not a file formate that is supported. Any suggestions greatly appreciated.
    cheers.
  • Eric Pautsch
    October 29, 2005 at 7:02 pm
    mmmm…your doing something wrong. All I can say is read the manual carefully. If your new to authoring it takes some time to learn the ins and outs.
  • Micah Et
    October 30, 2005 at 3:40 am
    yeah, that is what i did!
    in final cut >export>using compressor
  • Eric Pautsch
    October 30, 2005 at 5:08 pm
    When compressor comes up you need to set your bit rate then use AC3 audio to import into DVDSP
