Activity Forums DVD Authoring DVD Studio Pro – skipping copyright disclaimer button
  • DVD Studio Pro – skipping copyright disclaimer button
    Posted by Ben Trahair on August 3, 2008 at 3:14 pm
    Hi All,
    I’m trying to write some scripts to control when a copyright disclaimer appears on a DVD. Basically what I want it to do is play only the first time the disc is inserted. If the user presses the DVD menu button while on a menu I want it to return to the root language menu – not the first play
    I have the disc set up as:
    First play: track – Copyright disclaimer – prescript:
    Jump Language Menu if (GPRM 0 = 1)
    End jump for disclaimer track – Language Menu
    Language Menu: Prescript:
    mov GPRM 0, 1
    It then has a series of links to other submenus.
    My understanding was that if I assigned a variable of 1 in the language menu prescript then the disclaimer pre-script should automatically skip to the language pre-script. But it doesn’t work – when I press the menu button whilst on a menu page it goes back to the disclaimer track.
    I’m probably going round this the wrong way. Does anyone have any ideas or know any tricks to get around this? I have a deadline looming and would be really appreciative if anyone could help me get it sorted.
    Ben
    Noah Kadner replied 18 years, 1 month ago 3 Members · 3 Replies
  • Eric Pautsch
    August 3, 2008 at 6:09 pm
    The Menu button wasn’t designed to be pressed during a menu and expect it to take you to another menu….at least not in DVDSP. Just put a button on the menu to return to the root menu.
    But if you insist, I’d put a short 1 sec piece of black in the track 1 position with an end jump to the root menu.
  • Ben Trahair
    August 3, 2008 at 7:54 pm
    Thanks so much Eric. This is great. Out of curiosity would you think consider it dangerous to use less than a second of black?
    Cheers,
    Ben
  • Noah Kadner
    August 3, 2008 at 11:42 pm
    I’d stick with 1. Any less and you have encoding, playback issues potentially.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
    https://www.callboxlive.com
