Activity › Forums › DVD Authoring › DVD STUDIO PRO playback issues
Posted by Kirk Johnson on September 13, 2007 at 8:58 pmHey all,
I’m trying to author a dvd using DVD studio pro and am having some problems. I burn the dvd successfully and re-insert it into my mac and it plays back just fine. But when I put it into a stand alone DVD player, the player isn’t able to read it. It says that it is an unknown disk. I’m sure it’s a simple option that I have clicked incorrectly. Can someone please offer any amount of advice?
Kirk
Benjamin Eshagpoor replied 18 years, 10 months ago 5 Members · 6 Replies -
Marcus Remberger
October 24, 2007 at 12:07 pmIn your VIDEO_TS folder, that was created when you built
the project from DVD Studio pro, are there any files called
.layout and .lay??
If so, delete those and burn the VIDEO_TS and AUDIO_TS again
onto a DVD. Try now, it might work. -
Jobel Quiambao
October 30, 2007 at 1:05 amWhich DVD burning software did you use?
ManOne Productions Ltd.
Benjamin Eshagpoor
November 8, 2007 at 2:58 pmWhat does deleting the .layout file do?? I’m just curious. I’m having a similar issue with a project that I did for a client. They want maximum playability. The DVDs seem to play just fine on DVD players that have been made within the last couple of years, but they don’t play very well, if at all, on DVD players that are several years old.
bE
Max Kovalsky
November 8, 2007 at 3:07 pmLayout files tell DVDSP’s pre-mastering engine if it’s a DVD 5 or 9 and if 9 where the layer break is. Keeping or deleting them files won’t make much difference, and if you’re burning out of DSP, it won;t include them on the disc anyway.
This may be surprising, but there are still players out there that will not play DVD-Rs, only pressed DVD-Video discs, which is a different beast.
Max
Author
New York
Area4.tv -
Benjamin Eshagpoor
November 8, 2007 at 3:36 pmSo, if I have a Dual-layer DVD, and I delete the .layout file inside the VIDEO_TS folder, will it still play or will said DVD player not know where the layer break point will be?
Again, just curiuos.
All the best,
bE
Benjamin Eshagpoor
November 9, 2007 at 8:37 amI use DVD Studio Pro. Essentially, I’ve never done mass duplication of DVDs before, so I’m new to the game. I created a set of DVDs out of DVD Studio Pro and gave them to the client for duplication.
The client tells me that they’ve tested some of the duplicates that they’ve made from the copies that I made, and they’re not playing on some machines.
I have a friend that tells me that what they should’ve done is sent what I gave them to get mastered to a “glass” print so the duplications could be made from that. I’m a novice of course, so I have no clue what any of this means.
Lemme know,
bE
