Activity Forums Apple Final Cut Pro Legacy DVD Studio Pro – need help on buidling! [beginner]
  • DVD Studio Pro – need help on buidling! [beginner]
    Posted by Tiffany Duke on October 17, 2009 at 2:18 pm
    I am in the process of building/formating to burn my HQ short in DVD Studio Pro. I am a beginner and n00b with DVD SP, downloaded the manual and still confused, please help!
    I have dragged both audio and video into a Track. I now need to set the track for First Play – but cannot find this for the life of me!
    I then would like to have a main menu – add buttons [with Text with movie title] – that then play the movie. Simple enough I would think, but I can’t figure it out.. please help a newb!!
    Thank you!
    Dukesup
    Dan Monro replied 16 years, 11 months ago 2 Members · 3 Replies
  • Tiffany Duke
    October 17, 2009 at 2:43 pm
    Also – I shot my film on a Panasonic HVX200 and the project is 720p60 at 23.97FPS.
    Do I want to set DVD Standard to SD DVD or HD DVD?
    Dukesup
  • Tiffany Duke
    October 17, 2009 at 3:01 pm
    Okay so I got impatient and I’m just burning the DVD without menu or anything fancy – so it will just play the movie when one enters the DVD.
    However – it appears to be stuck on “Initializing..” as it has been on this for an hour. Is this normal? Am I doing something wrong?
    Someone please help!
    Dukesup
  • Dan Monro
    October 17, 2009 at 7:54 pm
    Easy there, Dukesp. Initializing can take a while if your content is short.
    Drag a menu template from the pallette into your main window.
    Click on each element and change it to what you want.
    Delete any extra buttons or type.
    Click on the button you want to use to play your movie; now look in the inspector for the “asset” pull down. Point this to your movie track. Your target can be set to the same track also – another pull-down.
    Click on the track in the graphical layout. Set the “end jump” to menu.
    Click on the “simulate” button in the tool bar, see how you did.
    If it works as expected, burn it. Get some coffee and relax. Don’t sit there and watch it burn.
    Once its done, throw it in your DVD player and watch it on your TV, not your computer.
    If something is awry, use the inspector to tweak, or post back. Might take longer than 20 minutes to answer.
    If any of these windows I mention aren’t open, use the apple ‘window’ menu to open them.
    I’m pretty new to DVDSP also. Good luck. Hope it helps. There are good tutorials on iTunes and Youtube.
    Cheers,
    D
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.4 GHz Intel Core 2 Duo 2 GB ram
    Mac OS X 10.5.7
    GeForce 8600M GT Final Cut Pro 6.0.5 Quicktime 7.6
