Activity › Forums › DVD Authoring › dvd studio pro – movie won’t simulate under story marker
  • dvd studio pro – movie won’t simulate under story marker
    Posted by 3dmuscle on April 16, 2007 at 8:25 pm
    I thought i could figure this one out by myself but so far no success.
    I have a track with 38 short movies and using story markers so i can have the option of playing all or just single movies. My problem is 2 of the movies do not play through the story markers (does not simulate as well), it stays black and only the audio plays. I already tried everything, even rebuilding the track, once it worked but as soon as i exited DVD studio and reopened the file, same problem.
    It seems the movies themselves are fine, the marker on the track also works since i can simulate but the story marker accessing that track seems to be the problem
    Any help is greatly appreciated
    Eric Pautsch replied 19 years, 5 months ago 2 Members · 4 Replies
  • Eric Pautsch
    April 16, 2007 at 10:36 pm
    Hi
    I’ve had this problem as well some times as well. Build a disc and it usually works fine. Making a new project usually helps the issue.
  • 3dmuscle Create COW Profile Image
    3dmuscle
    April 17, 2007 at 1:00 pm
    Thanks Eric, i will try the rebuild, i really hope it works, it would be a lot of work to redo the trakks and stories
    Thanks again
    3dmuscle
    April 19, 2007 at 2:40 pm
    I tried fixing the track but still there was one movie not playing/simulating. I created an image on my harddrive and tested it out and it plays fine, so not sure what the problem is.
    thanks
  • Eric Pautsch
    April 19, 2007 at 6:29 pm
    Did you try moving your tracks in different order in your outline? I usually place my track from the smallest on top to the largest on the bottom and this usually works. I think this is some kind of minor bug that needs fixing up as long as you have a working disc image your good to go.
