Activity Forums DVD Authoring DVD Studio Pro messing up my tranisitions, making video look jittery?
  • DVD Studio Pro messing up my tranisitions, making video look jittery?
    Posted by Brent Altomare on March 17, 2006 at 12:28 am
    I am having some repeated trouble with this and would appreciate any suggestions. I make my timeline in FCP, export a QT, put the QT through Compressor (MPEG2-60 minute High Quality Encode-all), drag those files (aiff, MP2) into DVD Studio Pro, make by DVD, “build it” in DVDSP, and then burn it in Toast. Now the problem is that my final DVDs have what I call garbage in the transitions, it almost looks like a noise filter in the middle of my cross fades. The other porblem that I am seeing is some of the video looks jittery and jumpy, as though you’ve slowed it down in a weird way and it’s skipping through the clip. This doesn’t happen on every DVD and it doesn’t happen all throughout the affected DVDs. But it happens enough that I know it’s a problem adn I can’t figure out what I’m doing wrong. I am attatching a link to 2 stills of the “garbage” in the transitions, as it is hard to explain and imagine without seeing it. Look in the top left and right corners. You see some pink boxes appearing and some other box shapes appearing. For reference, still 1 is crossfading into still 2, and stills A and B are still taken from the crossfade. It is difficult to see the full effect with out the moving video, so I am also inlucing a link to the actual clip of the transition. Thanks.
    http://www.groovylikeamovie.com/Still1 ; http://www.groovylikeamovie.com/Still2 ; http://www.groovylikeamovie.com/StillA ; http://www.groovylikeamovie.com/StillB ; http://www.groovylikeamovie.com/transition
    Brent Altomare
    Groovy Like a Movie
    (877) 3-GROOVY
    Ron Shook replied 20 years, 6 months ago 3 Members · 2 Replies
  • Bill Stephan
    March 17, 2006 at 4:32 pm
    If your dissolves look noisy, the bit rate for the MPEG encoding is too low, or you need to do VBR encoding. A dissolve is the most difficult piece of video to encode, as every pixel is changing across both space and time. That is what MPEG tries to compress. If every pixel is changing, it doesn’t compress well and the picture quality suffers (looks noisy).
    High-end hardware and software encoders have ways of dealing with these problems.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Ron Shook
    March 18, 2006 at 9:40 am
    Bill,
    [Bill Stephan] “If your dissolves look noisy, the bit rate for the MPEG encoding is too low, or you need to do VBR encoding. A dissolve is the most difficult piece of video to encode, as every pixel is changing across both space and time. That is what MPEG tries to compress. If every pixel is changing, it doesn’t compress well and the picture quality suffers (looks noisy).”
    All very true, but it sounds to me like his problem is in the other direction, i.e., too high a bit rate. I don’t know Compressor, but “60 minute” sounds like max DVD bit rate which would make the results jumpy at least in spots on many set top players.
    Maybe?
    Ron Shook
