Activity › Forums › DVD Authoring › DVD Studio Pro + Incompatible .movs?
  • DVD Studio Pro + Incompatible .movs?
    Posted by John Eberhart on July 16, 2008 at 3:37 pm
    I’m trying to author a DVD of a product for the company I work for, however, after exporting the freshly edited footage to Quicktime, only half of the files were “compatible” with DVD Studio Pro.
    I exported them all the same way, and sequentially. The only difference is (well, at least that I can tell) that the ones that I am able to import into DVDSP are in the dimensions of 720×480, whereas the “incompatible” ones are (for some reason) 1280×720.
    If this is a problem with Final Cut (let me know) then I may cross-post this if applicable.
    Any insight and/or help would be much appreciated.
    John E. Eberhart
    Eric Pautsch replied 18 years, 2 months ago 2 Members · 1 Reply
  • Eric Pautsch
    July 16, 2008 at 4:35 pm
    DVD is 720×480 only. Those QT didn’t import because they are 1280×720. You should be using Compressor to Encode your QTs – NEVER just drop a QT into DVDSP and let it doing the Encoding.
    Take them into Compressor and encode 16×9.
