Activity Forums DVD Authoring DVD Studio Pro: “incompatible format”
  • DVD Studio Pro: “incompatible format”
    Posted by Stephanie Holz on September 23, 2010 at 11:14 pm
    ok, so some progress has been made,
    I exported using “current settings” for a .mov file, then brought into compressor, and made a custome setting (H264)— did I see DVD SP doesn’t support this? The image quality of the resulting file looks good, but it says its a quicktime movie, and DVD SP still says “imcompatible format”— from what I can tell, DVD SP seems to like m2v files, but every time I make one, the image quality drops radically. Is there away to make a m2v file with more sharpness?
    many many thanks!!!!
    thanks!!!!!
    -SH
    Michael Sacci replied 15 years, 11 months ago 3 Members · 2 Replies
  • Noah Kadner
    September 24, 2010 at 12:25 am
    Nope- DVDs are only MPEG-2. This is in your manual.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
  • Michael Sacci
    September 24, 2010 at 12:42 am
    [Stephanie Holz] “and made a custome setting (H264)”
    H264 should NEVER be in the DVD workflow, NEVER!.
    I’m not a bitvice fan, while it does a good job, it seems like I run into pixelation problems a lot more then with compressor.
    I would keep this simple.
    From FCP, send the sequence to Compressor (Send to Compressor command)
    Start with any DVD Prest
    In the Encoder Button
    In Video Format
    Frame Rate: <29.97>
    Aspect <16:9>
    Field Dominance: Upper
    In Quality Tab – change the encoding method to CBR and
    Bit rate to 7.5
    In the Frame Control Button
    Frame Control
    Resize Filter:
    Encode the audio to ac3.
