Activity Forums DVD Authoring DVD Studio Pro freezes on certain dialogs (SOLUTION)
  • DVD Studio Pro freezes on certain dialogs (SOLUTION)
    Posted by Christopher Smith on August 2, 2017 at 10:15 pm
    Using DVD Studio Pro with later MacOS versions has become quite an adventure, but here are some things I’ve found:
    1. Most importantly, you should obtain a copy of OS X Server for Snow Leopard, and build a virtual machine. Install Final Cut Studio on that VM in order to have a fallback position in case DVDSP completely breaks.
    2. I’m currently running DVDSP on Sierra, and I of course must select button overlay colors based on position in the list, working blind.
    3. When I select Build to build a disc, DVDSP sometimes freezes while trying to animate the file selection dialog box, requiring a Force Quit. (At least DVDSP returns to the same project on reload.) I’ve found a solution:
    In Terminal, enter the following command:
    defaults write -g NSAutomaticWindowAnimationsEnabled -bool false
    This doesn’t turn off all the animations, but it seems to have disabled the dialog box zooms that have frozen DVDSP.
    Christopher Smith
    CBN International
    Tod Hopkins replied 8 years, 3 months ago 2 Members · 1 Reply
  • Tod Hopkins
    June 12, 2018 at 4:34 pm
    You saved me! I thought I was done with DVDSP on this system. That worked like a charm and it speeds up the system.
    Cheers,
    tod
    Tod Hopkins
    Hillmann & Carr Inc.
    Washington, DC
