Activity Forums DVD Authoring dvd studio pro -encoding settings
  • dvd studio pro -encoding settings
    Posted by Matt Goldschmidt on June 6, 2005 at 10:27 pm
    what is the BEST encode settings?
    Video standard – NTSC (of course)
    Aspect ratio – 4:3 (of course)
    Field order – ?????
    Encode Mode – ????
    Bit Rate – ???
    Max Bit Rate – ???
    Motion Estimations- ???
    Help – If had some hang ups and freezing.
    Im using quicktime (same as source) direct out of Final Cut Pro HD
    Thanks….
    Arnie Schlissel replied 21 years, 2 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    June 7, 2005 at 12:59 am
    [Matt Goldschmidt] “what is the BEST encode settings?”
    I’m mot trying to be cagey, but the best encoding settings vary from project to project.
    [Matt Goldschmidt] “Field order – ?????”
    Depends on your source material. DV is lower field 1st.
    [Matt Goldschmidt] “Bit Rate – ???”
    Depends on how much material (total # of minutes, including extras) is going on how big a disk.
    [Matt Goldschmidt] “Max Bit Rate – ???”
    No higher than 7 for disks being burned on a desktop. That assumes that you’re compressing your audio with aPack.
    Arnie
    https://www.arniepix.com
