Activity Forums Apple Final Cut Pro Legacy DVD Studio Pro burning issues
  • DVD Studio Pro burning issues
    Posted by Hariharan Swaminathan on August 14, 2011 at 5:59 pm
    I figured out to include the chapters in the menus. When simulating everything works as expected. I set the first play to Menu. But when I burn it as SD or HD DVD the dvd was playing from the middle of somewhere in the song. I have resolved that too. Now when i burn this and put it in a dvd player or wii player or open the disk at vlc player it is not working. I don’t know why.
    If i point that caches folder directly on vlc it is working as expected. What is that am doing wrong in burning? Why am not able to play?
    It has created HVDVD_TS & JACKET_P folder. Does anyone have experienced this?
    Please assist. I am stuck. And what bit rate is good for a high definition and also to play it in a projector?
    | Hariharan Swaminathan |
    photographer | film maker
    http://www.ihariharan.com
    http://www.vimeo.com/ihariharan
    http://www.youtube.com/ihariharan
    Chris Tompkins replied 15 years, 1 month ago 2 Members · 3 Replies
  • Chris Tompkins
    August 14, 2011 at 8:48 pm
    HD DVD is a dead format. You want BluRay if you’re trying to create a HD Disc.
    DVDSP will create a SD DVD for you.
    Create your mpeg2 files b/4 importing them or import your QT files directly.
    Chris Tompkins
    Video Atlanta LLC
  • Hariharan Swaminathan
    August 14, 2011 at 9:15 pm
    Thanks for your response. I already have my QT file exported with current settings (Apple prores hq) from fcp directly which is around 7.55 GB in size. I imported that including chapter markers in DVDSP. As i said earlier, i tried hd dvd and i also burnt SD DVD by going to project settings and used the SD DVD. It’s still not playing in the DVD player.
    I have done lots of work in the menus. Is there anyway i could correct it in the project here in DVDSP and burn it in SD and make it work?
    Could you pls tell me the workflow? Thanks!
    Hariharan
  • Chris Tompkins
    August 15, 2011 at 10:35 am
    Have you read the DVDSP manual?
    It sounds like you have the basic knowledge of how it works and how easy it is to make a DVD.
    Cashe, VLC, TS Folders: You shouldn’t bother with ANY of this.
    Burn the disc direct in DVDSP.
    If simulator works fine. Put in a Blank DVD-RW (good for tests) Burn.
    Test disc on a normal DVD player hooked up to a TV. Not sure what the problem is. If a song is playing from the middle of the track then you told it to play that way.
    Chris Tompkins
    Video Atlanta LLC
