Activity › Forums › DVD Authoring › DVD Studio Pro: Assets, Source Specifications
  • DVD Studio Pro: Assets, Source Specifications
    Posted by Byuprod on April 17, 2006 at 3:32 pm
    I”m having issuses with two of my mpeg2 in dvd studio pro, they are fine in this simulator and when you playback on the computer, but when you burn the dvd and play it back on a tv monitor the video gets jumpy and jittery. What are the best specifications for the source before it is converted into an mpeg2? Has anyone else had this problem? Thanks so much for any information you can give me.
    Don Greening replied 20 years, 5 months ago 2 Members · 1 Reply
  • Don Greening
    April 18, 2006 at 3:34 am
    Might be a field order issue. If the video you’re encoding is interlaced make sure you have the right field order selected e.g. If you’re using NTSC DV video the field order would be set to lower first.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
