Activity Forums DVD Authoring DVD Studio Pro 4 Track Icon
  • DVD Studio Pro 4 Track Icon
    Posted by Eric Holzapfel on August 25, 2013 at 5:57 pm
    I have searched for this in the Apple documentation and on the web.
    no luck. I have noticed that on a track I have created, and added video, there is a small triangle in the lower right of the track icon in the graphical view area. Does anyone know what this might be from?
    I also had on in a track that I used a motion project in.
    Perhaps it has to do with markers?
    One last question, I did have a track set as “First Play”. The track’s video was from a motion project (.motn file). This track was set as First Play – and when I simulated the DVD in DVD Studio Pro 4, this track plays and jumps to the next menu correctly. That is good. But, when I built the project, and used DVD Player app to test the Video_TS files, it would not play the “First Play” track, but the end jump of this track, which was set to a menu. This was working ok (??). I fixed it by deleting the First Play Track (which also had a small triangle in the lower right of the track icon), creating a new track, adding the video and audio, and then setting it as first play. That worked.
    I am open to suggestions.
    What about using Adobe Encore instead of DVD Studio Pro 4 – any suggestions there.
    Thanks for a great resource,
    Eric H.
    Eholz1
    Final Cut Pro, Adobe After Effects, Photoshop
    Eric Holzapfel replied 12 years, 12 months ago 2 Members · 4 Replies
  • Bill Stephan
    August 26, 2013 at 4:50 pm
    If it is a yellow triangle, that is an error message. Maybe your video track is encoded in a format that DVDSP doesn’t accept (H.264, VC-1, etc), or wrong video standard (PAL or HD in an NTSC project, for example). Check your encoding workflow.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Eric Holzapfel
    August 27, 2013 at 2:38 am
    Hello Bill,
    Thanks for the information. The triangle is not yellow, it is an outline of a triangle
    in the lower right part of the track, in the image area. I am using compressed m2v for the video.
    I used compressor for the conversion of an Apple Pro Res 422 QT file to mpeg2 for DVD.
    I just deleted the track, and re-added the video/audio, and what ever the small triangle
    meant, is gone. Mysteries of DVD Studio Pro.
    Can you recommend some other tool for encodeing mpeg 2 video for SD DVDs other than
    Apple Compressor?
    Thanks Again,
    Eric
  • Bill Stephan
    August 27, 2013 at 5:22 pm
    Hi Eric,
    I have to admit I don’t know what the outline of a triangle on your picture track means.
    For better encoding, there is a software plug-in for Compressor that gives you advanced encoding capabilities. I don’t remember what it is called. Maybe someone else can give you the name. We use mostly big-iron encoders here.
    Bill Stephan
    USA Studios
    New York City
  • Eric Holzapfel
    August 31, 2013 at 3:29 pm
    Hello Bill,
    Thanks for the info. It is not critical, but it is confusing. Probably buried somewhere
    in Apple’s documentation.
    I will check for compressor plug in – I did find a standalone program called Bit-Vise, but it is quite
    confusing – at the moment anyway!
    Eric
