Activity Forums DVD Authoring DVD Studio Pro 4 clipping Photoshop Menu Layers
  • DVD Studio Pro 4 clipping Photoshop Menu Layers
    Posted by Byuprod on December 20, 2005 at 7:33 pm
    Hello, I’m putting together a DVD with DVD Studio Pro 4, using layered menus from Photshop. For some reason the text in the photoshop file is clipped at the bottom. I’ve tried changing the fonts, raterizing them, re-sizing them, nothing seems to get rid of the clipping. Does anyone have any suggestions as to why this is occuring and/or how to fix it?
    Rich Rubasch replied 20 years, 8 months ago 3 Members · 2 Replies
  • Noah Kadner
    December 21, 2005 at 12:21 am
    Not sure- what do you mean by clipping? Cropping?
    Noah
  • Rich Rubasch
    December 21, 2005 at 5:04 am
    Sounds like the bottom of an “o” is sort of flat, like the bottom couple pixels that make it round down there are gone.
    What size is your Photoshop file? Is the text rasterized?
    Here’s my workflow/; Make the PSD file 720 x 534. Build all your layers. Do not rasterize type. When everything is done do a “Save As” and name it 480 final or some other name. Change the image size to 720 x 480 not constrainign proportions. This squeezes the type to the correct size but keeps it vector (clean).
    Now you can collapse your layers or rasterize your type and it should remain clean.
    If you’re PAL file sizes are different, but you get the idea. In the end you will end up with an unsquished file that you can edit your type and resave and resquish if needed for revisions, and the squeezed one is a copy with the type that was squeezed in vector format and rasterized for use in the final menu.
    Rich Rubasch
    Tilt Media
