Activity Forums Apple Final Cut Pro Legacy DVD Studio Pro
  • Posted by James Haefner on June 17, 2008 at 5:59 pm
    Hola Creative Cows:
    I read an article regarding outputting video projects through iDVD.
    It says it can not / will not support MPEG2 files.
    Because the original tapes were lost for a large part of my footage, luckily the guy transferred the footage to a DVD.
    Then I had to convert the file through MPEG2.
    My question and concern – Will I have a problem with either iDVD or DVD studio Pro? Which one should I use? I am scrambling, getting all sorts of different feedback and want to make sure I do the right thing. Thanks.
    James Haefner replied 18 years, 3 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    June 17, 2008 at 8:53 pm
    Use MPEG Streamclip to create DV files from the DVD you have… that file will edit, and it will then import to iDVD. If you want better, export that DV version to Compressor, and compress it back to MPEG to burn a DVD with DVD Studio Pro.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • James Haefner
    June 17, 2008 at 10:25 pm
    So I will fine making a DVD with iDVD? even though I converted some of the footage through an MPEG streamclip?
    I have iDVD…. I do not have Compressor or DVD Studio Pro… nor do I want to go through these steps…
    will iDVD do the job? Thanks.
  • Bret Williams
    June 18, 2008 at 2:59 am
    Your’e going to have to reconvert them to something iDVD can read, like DV. Then drop those into iDVD.
  • James Haefner
    June 18, 2008 at 1:19 pm
    To clarify:
    Print to tape > Then output my DV tape to > idvd?
    Sorry this is my first time creating a DVD and just want to make sure I get it right.
    One thing I know for sure is to always Print to Tape. Thanks.
