Activity Forums VEGAS Pro dvd structure guru needed: problem with precise executing of out points for chapters in DVDArchitect 5.0
  • dvd structure guru needed: problem with precise executing of out points for chapters in DVDArchitect 5.0
    Posted by Paul Beller on September 3, 2013 at 1:35 pm
    hi there.
    i have a dvd project in which i have a long video divided in chapters
    i need a player to go back after each chapter to the menu. that is easy – i know. i have my video in as many instances as i my chapters after which i need to go back to the menu, i have chapter markers and in/out points set precisely and on i-frames. i know all that. it works fine in dvd architect preview. but the player (power dvd, vlc player) there is about a second of each chapter missing at the end. why players don’t follow out points precisely? hoh to make them to follow out points?. In-points are perfect. The problem is only about out points. It probably has sth to do with GOP structure. I am not a guru in that. But some of you surely are. Please help how to fix that.
    Thanx
    P.S.
    I ve found another chap having more or less the same problem.
    https://www.designstudioschool.com/chapter-points-drifting-t52348.html
    Can any DVDGURU confirm that solution?
    Paul Beller replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
