Activity Forums DVD Authoring DVD sp3 wont open
  • DVD sp3 wont open
    Posted by Criis Daw on September 1, 2005 at 2:16 pm
    Anybody got any idea why my copy of DVD studio pro 3 wont open , or rather quits when i open a project or try to import an asset into a new project. I haven’t used it for some monthes and in the meantime the only difference is that i have installed the latest mac (10.4) OS on my computer. ??
    Any ideas or advice on where to get help very much appreciated.
    chris
    Daniel_l replied 21 years ago 2 Members · 4 Replies
  • Daniel_l
    September 2, 2005 at 10:06 am
    1st thing to try is to run a System update (under the Apple Menu – Obviously you’ll need an internet connection)
    2nd is to ditch the .plist preferences file and re-launch DVDSP
    3rd is to trash & re-install the Application.
    If all that fails try posting your problem to the Apple DVD studio Pro forum:
    https://forums.creativecow.net/cgi-bin/new_view_posts.cgi?forumid=155
  • Criis Daw
    September 2, 2005 at 1:41 pm
    Thanks for the advice, I will try it as soon as i am back at the studio
    cheers..
    chris
  • Criis Daw
    September 5, 2005 at 1:57 pm
    i have tried all that and still no joy ??
    any ideas?
  • Daniel_l
    September 5, 2005 at 2:15 pm
    Have you re-installed the application, (or did you copy it over from your previous system? – if you copied it across then it’s very unlikely to work)
    If you did a fresh install, and it still won’t open, then it points towards more serious, system-level problems and I would suggest backing up and doing a fresh, full system install (not an archive install).
