Activity Forums DVD Authoring DVD SP Widescreen Burning
  • DVD SP Widescreen Burning
    Posted by Chris Mast on October 4, 2007 at 5:27 pm
    I’m trying to burn a widescreen movie in DVD Studio Pro so it will play full widescreen on an HD widescreen TV, and then convert to letterbox when played on a 4:3 TV.
    I’ve set aspect ratio to play both “pan & scan 16:9”, and “4:3” in DVD SP preferences but when I play the video on a widescreen TV it vertically distorts the image. Everybody looks fat and squished.
    Could it be that I’m compressing the video right in DVD SP when I import the files? My compressor doesn’t work so I’ve been importing the files as Quicktime files and letting DVD SP compress when compiling.
    Thanks a lot!
    Chris Mast
    Max Kovalsky replied 18 years, 11 months ago 3 Members · 2 Replies
  • Noah Kadner
    October 4, 2007 at 5:44 pm
    First you need to be sure you encoded your MPEG-2 video in true anamorphic 16:9 rather than 4:3 letterboxed. Then pick the 16:9 letterbox setting in DVDSP. If it looks correct in the simulator you are good to go.
    Noah
    Unlock the secrets of the DVX100, Apple Color and now the HVX200!
    https://www.callboxlive.com
  • Max Kovalsky
    October 7, 2007 at 8:20 pm
    Chris,
    Go to your DVDSP preferences, click on “encoding” tab and select 16:9 under “Aspect ratio”. I bet yours was set to 4:3.
    Max
    Author
    Area 4
    New York
