Activity › Forums › DVD Authoring › DVD SP language codes?
  • DVD SP language codes?
    Posted by Robert Crockett on March 11, 2007 at 10:12 pm
    Hi, I trying to burn a project and keep getting a failure note right off the bat saying ” language codes for ‘English ‘ and ‘ English-2’ must differ ” . I’m not usuing any scripts,subtitles or storys.. pretty straigt forward. The only thing I’m doing differently than usual is using AIFF audio instead of dolby 2.0 because the project is small enough. Any hints on this one would be greatly appreciated!!
    Rob
    Robert Crockett replied 19 years, 6 months ago 2 Members · 2 Replies
  • Eric Pautsch
    March 12, 2007 at 12:50 am
    This happens often..so don’t feel bad 🙂 You’ve duplicated your original language by mistake. Look in the Outline at the bottom. There you’ll see “English” & “English-1”. Delete “English-1” and try another build.
    Eric
  • Robert Crockett
    March 15, 2007 at 9:14 pm
    Thanks for the info. Before I discovered your response, I started again from scratch and fortunately didn’t make the same error.
    I am not clear what you mean by the “outline” on the bottom. I couldn’t find it.
    If you happen to see this could you elaborate a little on where it is? I’d love to find a better way than having to start over!
    Thanks, Rob
