Activity Forums DVD Authoring DVD skip,hang, What should I do?
  • DVD skip,hang, What should I do?
    Posted by Matt Goldschmidt on June 6, 2005 at 6:26 pm
    My final product skips and hangs. What is the best DVD to burn to? sony,memorex, etc.
    Its gota be a – , and I am using DVDStudioPro 2.
    Is there a sensitivity setting for the burn stage?
    Im on a mac 0sx – should I close all programs during burn? Could that be causing a colflict?
    Finally, I dont thik this has anything to do with it, but I used FinalCutHD to export (quicktimes)
    HELP
    thanks
    Matt Goldschmidt replied 21 years, 3 months ago 3 Members · 5 Replies
  • Ed Dooley
    June 6, 2005 at 8:33 pm
    Are you creating an MPEG2 before burning? And at what bit rate?
    Ed
  • Chris Borjis
    June 6, 2005 at 9:15 pm
    Your bitrate should not exceed 7,000
    Your audio should be Dolby AC-3 around 256kbps or better.
    Quality Media like Verbatim & Ritek/Ridata will help as well.
  • Matt Goldschmidt
    June 6, 2005 at 9:17 pm
    so…. how do I set these in DVDStudio Pro 2? I have been using the defult bun
  • Chris Borjis
    June 6, 2005 at 9:23 pm
    It’s during the compression step.
    How are you compressing your video?
    With apple compressor or quicktime perhaps?
    also, you should be burning the disc at 1x just
    for extra precaution.
  • Matt Goldschmidt
    June 6, 2005 at 9:31 pm
    I guess Im just using the defult. How do I get to the compression settings.
